rpm jumping up and down in different speed
Old Mar 25, 2004 | 07:46 PM
dc2integra's Avatar
dc2integra
Default rpm jumping up and down in different speed
my rpm seems to jump after it hits 2. when i go higher speeds..it jumps to 5 6 7 and then 3 , well it really just jumps around back and forth as i go faster. what could the be the problem? and how do i fix it? its an automatic integra
i added fuel treatment and flushed my transmission and it jumps back and lesser now. is it cause my fuel injectors are dirty?
Old Mar 26, 2004 | 04:12 AM
JimBlake's Avatar
JimBlake
If the engine speed were actually jumping around from 3k up to 6k or 7k, it would be so obvious to feel you wouldn't need a tachometer. So I bet it's just the tach jumping around, right?
If so, flushing transmissions & cleaning injectors isn't gonna deal with the real problem. Wiring problem or loose connections SOMEWHERE at your distributor or tachometer or somewhere in between.
Got a multi-meter & a wiring drawing for your car? That's what you need.
Old Mar 26, 2004 | 04:18 AM
dc2integra's Avatar
dc2integra
ok i'll try and check that, thanks
