hight-flow catalyic converter vs oem catalytic
Old Mar 19, 2004 | 05:46 AM
jp184's Avatar
jp184
Default hight-flow catalyic converter vs oem catalytic
There are really a difference in performance, power or torque, between a original catalytic and a high-flow catalytic converter or vacuum on a civic SI if I do not change the remainder of the exhaust (I just changed the muffler, ECU, cams ITR and Iceman Like)
Old Mar 19, 2004 | 06:54 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
High flow cat is more beneficial when your engine is flowing a significant amount of air more than stock, so if you keep a stock exhaust, you shouldn't lose power, but you won't gain any either.
-Harry
AIM: NDcissive
Old Mar 19, 2004 | 06:58 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
A high flow is also a good bit cheaper than stock, so if you need to replace the cat anyway you might as well go with a high flow unit. But, you won't see any increase in power unless the rest of the exhaust (header, cat back) is opened up and the engine actually needs the extra flow capacity.
jdmkings
Vehicle Classifieds
14
Jun 11, 2004 03:59 PM
RKV
Dec 31, 2002 07:40 PM
RKV
Nov 16, 2002 09:41 PM
GSRspeedracer
9
Oct 3, 2002 06:26 PM
