H22 head on H23 block
Old Mar 2, 2004 | 05:21 AM
hybridbuildup69's Avatar
hybridbuildup69
Default H22 head on H23 block
Is an H22 head a direct bolt on to an H23 block? If not, what needs to be done for it to fit? I'm wanting to run a t03/t04 turbonetics turbocharger on this setup???
Old Mar 18, 2004 | 03:17 PM
QuaaludeSi's Avatar
QuaaludeSi
94 Prelude Si
Not worth it. The head will bolt up - there is some oil passage issues, and a number of problems you will run into when doing the swap. I sarted to research it, it is better to go with the entire h22. If you want some real good tech info on it go to honda-tech.com and do a search. There are threads there that will tell you exactly what you need from each engine and the problems that other people had. My suggestion either turbo the h23 or h22, forget the hybrid.
jlude92
Prelude
2
Jan 29, 2004 07:25 PM
Smoknjimer
Prelude
2
Apr 4, 2003 11:28 AM
PSPEC
Engine Swaps, Tech & Tuning
15
Mar 11, 2003 03:15 PM
tim
Prelude
5
Nov 19, 2002 12:35 PM
IrradiatedKitty
3
Oct 22, 2002 04:27 PM
