Thinner Head Gasket for D16?
Old Feb 29, 2004 | 11:37 AM
spdracer22's Avatar
spdracer22
Default Thinner Head Gasket for D16?
Is there someone who makes a thin head gasket for a D16Y7? I'd like to get a little bit more power from an increase in compression (engine has to be "stock" i.e. no turbo/etc. per SCCA rules)...but is it worth the effort, even if I do find one? (Anyone know a rough power increase?)
spdracer
Old Feb 29, 2004 | 01:24 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
~2whp up top maybe
Old Feb 29, 2004 | 04:42 PM
DanM's Avatar
DanM
If that. Not worth the effort.
Old Feb 29, 2004 | 09:41 PM
S2Kev's Avatar
S2Kev
You could just use the d16y8 head gasket and remove the middle layer. I'm not sure how much power you'll gain from it as you'll just get slightly higher compression. You may not even feel the gain.
Old Mar 13, 2004 | 01:58 PM
Splishkanake's Avatar
Splishkanake
JDM PWR
Before you remove a gasket or put a thinner one on, you better check your valve to piston clearence. All you need is some bent and broken valves the first time you crank that engine!
Old Mar 13, 2004 | 02:00 PM
DanM's Avatar
DanM
Tons of clearance. You could have NO gasket whatsoever on a stock Y8 head and still not bash a valve.
Still, there's no point in doing this. Won't get you anywhere at all.
AccordinglyDone
Accord
27
Mar 2, 2004 05:51 AM
westcoaststyle
92+ Civic/EL & Del Sol
11
Aug 17, 2003 09:36 AM
slowintegra90
Jul 8, 2003 06:29 PM
IrradiatedKitty
Engine Swaps, Tech & Tuning
3
Oct 22, 2002 04:27 PM
AwwsChwA
5
Sep 29, 2002 07:22 PM
