Grounding Kit differences.
Old Feb 27, 2004 | 10:41 PM
S2Kev's Avatar
S2Kev
Dang 4 gauge? That's pretty thick ground wiring. I agree with qtiger, 8 gauge should be fine. If you really feel the need to get gold plated connectors then get it. I'd probably get them depending on the price.
Old Mar 20, 2004 | 03:19 AM
Pawpawsmurph's Avatar
Pawpawsmurph
Pawpawsmurph
No no no, go with the 4 gauge. It's a little expensive but it'll pull more power out meaning more power will flow easier through your engine, a benifit for better spark. But why waist your money on gold plated connectors. Tinned copper will give you a good contact for all your needs.
Old Mar 20, 2004 | 07:30 AM
b00gers's Avatar
b00gers
im on my way of making my own. i say if you know how to crimp big wires, do it yourself. the "kits" charges a load of money.
4 guage wire cost $.99 per feet. you wont need more than 10 feet. crimps cost $.50 per. and if you dont have a good crimper, $20 can get you an impact crimper for working wth the 4 guage. then put in some time to sand the paint off the chassis...:dunno:
im planning on using 4 guage wires from these points:
-valve cover to chassis
-negative battery terminal to chassis
-positive lead on alternator to battery (as well as keeping the stock lead)
robert made a good write up in the car audio section.
Old Mar 31, 2004 | 03:36 PM
silverDC4's Avatar
silverDC4
R-Spec
i made my own earthing system.
I regrounded all the stock wires and added some ground points.
I have noticed a pretty significant difference in the "performance" of my engine.....It idles better, a lil increase in gas milage (like 1 -2 mpg), and it goes through the rpms much more smoothly then before.
but my car is 8 years and 100k miles old and the stock grounds were just shit....
I replaced the stock tranny ground w/ a 4 gage wire
replaced the wire from the neg bat terminal to the chasis w/ a 4 gage
replaced the valve cover ground w/ a 8 gage
added 8 gage ground wires from the neg bat terminal to the throttle body and intake mani
and added a 4 gage ground wire from the neg bat terminal to the alternator
Old Mar 31, 2004 | 08:33 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Here's a couple threads that might help out; although, the pics are now dead.
https://www.honda-acura.net/forums/s...ghlight=ground
Old Mar 31, 2004 | 09:43 PM
qtiger's Avatar
qtiger
I think my freakin jumper cables are 4 gauge. :eh:
Old Apr 1, 2004 | 02:05 PM
silverDC4's Avatar
silverDC4
R-Spec
yea they prob are, 4 gage is pretty big.....
Old Sep 14, 2004 | 08:38 AM
ACCORDDUST's Avatar
ACCORDDUST
ChicagoLand Accord Club
i am waiting for my ground kit . now do i replace the old ground wires or just put the new ones over the old ones?
Old Sep 14, 2004 | 11:25 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I bought the HKS Circle Earth for my 99. It's universal and I noticed that it did idel better, my fuel economy increased slightly and my headlights were brighter. Towards higher RPM's you noticed a little bit of a difference, but nothing worht writing home about. It looks good under the hood though. Better than the factory grounding straps.
Old Sep 17, 2004 | 02:05 PM
ACCORDDUST's Avatar
ACCORDDUST
Default my wires
so i did my ground wires today here are the pics.
i couldnt get these 2 bolts off i want to put it here to but i need metrix sockets right ?
here is from the bat to the cyl Head hopefully this gold bolt is ok
i took my intake box off and put a ground where LX4CYL said we should put one
my last one i put on was to the Strut on the passanger side
This is what it looks like on my battery
