Temperature Fluctuates...Help
Old Feb 24, 2004 | 02:28 AM
lestah's Avatar
lestah
Default Temperature Fluctuates...Help
My temp goes above normal but not into the red zone then comes back down to normal... i think it goes back to normal once the radiator fan starts. what do u think is wrong? can i be the temp sensor ****ed up or what?
Old Feb 24, 2004 | 06:25 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
What coolant mix are you using?
-Harry
AIM: NDcissive
Old Feb 24, 2004 | 08:01 PM
RiGgEdB18B1's Avatar
RiGgEdB18B1
B18B1 is the best!
it could be the thermostat
Old Feb 25, 2004 | 02:34 AM
drift's Avatar
drift
Flaccid Member
good chance you have an air bubble in your cooling system... when the bubble passes over the temp sensor, it goes wildly high, then comes back down once the bubble passes.
Old Feb 25, 2004 | 07:41 AM
ludeboom's Avatar
ludeboom
you should change your thermostat and coolant, make sure to bleed air out of the system afterwards.
AND USE PREMIXED COOLANT
or
if u mix your own, make sure you use distilled water.
we have aluminum blocks people, do the math
~boom
HH814
Sep 15, 2002 02:53 PM
