D16Z6 vs. D16Y8
Old Feb 11, 2004 | 06:10 PM
dx2gsr's Avatar
dx2gsr
Default D16Z6 vs. D16Y8
Hey everyone! Its been awhile since I've last posted but life's been busy between school and work. In the last couple of months, I've recently purchased a 1995 Civic EX with 120,000 miles, 5 spd, and all the bells and whistles but all of that is regardless. My question is, what are the differences between the D16Z6 and the D16Y8 motors? They are both in the EX models between 92-00. Are there any major differences?
Old Feb 12, 2004 | 06:55 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Z6 is from '92-'95 and is run by an OBD-I ECU, Y8 is from '96-'00 and run by an OBD-II ECU. Aside from that the main differences are in piston dome and combustion chamber volume.
Old Feb 13, 2004 | 01:49 PM
S2Kev's Avatar
S2Kev
The combustion chamber shapes are also different. The d16z6 has a hemispherical shape and the d16y8 combustion chamber is squared. The d16z6 combustion chamber holds more volume than the d16y8. Because of the d16y8 smaller combustion chamber, the head yields higher compression than the d16z6.
Old Feb 16, 2004 | 03:51 PM
Gearheaddave's Avatar
Gearheaddave
So which one is better for doing mods to?
Old Feb 16, 2004 | 06:36 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
depends what you wanna do.. n/a or boost? n/a probably d16y8 for higher compression.. although when you go to do internal mods it wont' make too much difference for you will be getting higher compression pistson for either.. so i'd say stick with your d16z6 and build that.. they both have ~ same hp and tq... if any difference at all.. i'd stay with OBD-I over OBD-II anyway
Old Feb 16, 2004 | 06:37 PM
ZiviCase10287
RacinMasonC
sorry that was for the person who started the thread i thought Gearheaddave started it.. my bad
edit: i'm stupid.. gearhead also has the z6 :jawdrop:
Old Feb 17, 2004 | 04:15 PM
S2Kev's Avatar
S2Kev
The d16z6 flows better and it's good for high end power.
Old Feb 17, 2004 | 04:26 PM
Gearheaddave
Sweet so I guess I have a decent motor..
Old Feb 24, 2004 | 08:17 PM
Type-R #00026's Avatar
Type-R #00026
Well what about the z6 head on an d15b7 block. Is this a good set-up and why? What mods are best for this set-up?
92CivicDX
92+ Civic/EL & Del Sol
8
Oct 22, 2005 07:46 AM
MaDwAcKoOpS
May 5, 2003 11:54 PM
NewbieCivic
8
Mar 20, 2003 06:28 AM
93civex
2
Feb 6, 2003 02:39 AM
96sedanR
9
Aug 15, 2002 04:00 PM
