Storing an engine?
Old Feb 7, 2004 | 06:57 PM
cvcsleeper's Avatar
cvcsleeper
Boyashaka!
Default Storing an engine?
If you get an engine out of a vehicle for a while (1-2 months), what do you do to make sure the internals don't seize up or rust?
I was told to fill the engine up to the valve cover with oil. I was told that once the engine was installed, it would smoke for a couple of days because of all the oil but after that it would be fine.
Do you have any other suggestions or is this a good technique?
Old Feb 7, 2004 | 11:34 PM
Nathan1234's Avatar
Nathan1234
Domestic Driving Asshole
When storing small block V8's, I've always dumped oil in the carb until it starts smoking A LOT, then kill it. I've pulled the heads after 3+ months of storage and there is ZERO rust. Afterwards, just start it, let the oil burn off (lots of smoke), replace the plugs, and go.
I would imagine that this same method would work on a fuel injected engine, but it would likely involve a funnel and a disconnected vacuum line.
Old Feb 8, 2004 | 04:51 AM
drift's Avatar
drift
Flaccid Member
i normally coat every internal STEEL or IRON surface with WD-40, wrap the whole thing in a garbage bag, stick a shopvac hose into the bag to suck out whatever air i can then seal off the end of the bag tightly.
never had a rust problem.
Old Feb 8, 2004 | 05:09 AM
cvcsleeper's Avatar
cvcsleeper
Boyashaka!
Cool, thanks for the suggestions, I was also told to put a tablespoon of oil in each cylinder. That's similar to whatyou guys mentioned.
Thanks
Old Feb 8, 2004 | 09:03 AM
qtiger's Avatar
qtiger
Thanks
If you do it that way, make sure to crank it over a couple times with no fuel, no spark. That'll spread the oil around the sleeves.
Old Feb 8, 2004 | 01:38 PM
cvcsleeper's Avatar
cvcsleeper
Boyashaka!
Will do, thanks. Should I leave oil in the oil pan or drain it?
Old Feb 10, 2004 | 03:07 AM
drift's Avatar
drift
Flaccid Member
flush it, considering the engine removal process probably leaked some coolant into the oiling system.
RaVen_CiviC
92+ Civic/EL & Del Sol
34
Sep 24, 2004 06:11 PM
se93
Engine Swaps, Tech & Tuning
Jul 4, 2003 07:56 AM
98CoupeV6
News & Rumors Archives
16
Jun 19, 2003 03:10 PM
Tirod
31
Mar 3, 2003 05:13 PM
jaje
Jul 11, 2002 08:01 AM
