Oil on Spark Plugs
Old Feb 7, 2004 | 11:53 AM
Dreemer's Avatar
Dreemer
KOJ MOB PIM
Default Oil on Spark Plugs
I have a v6 and one side got oil on the spark plugs. It has rough idle making the rpm needle moving up and down. I think the rough idle is from the EGR valve, but why would oil be on the spark plugs? Could it be a bad gasket?
Old Feb 7, 2004 | 01:56 PM
vassil3427's Avatar
vassil3427
Oil on the porclin part or the actual diode? If its on the porclin then you need to get a valve cover gasket kit(very inexpensive)....If its on the actual diode, then maybe your piston ring(s) are shot... And a bad egr valve can cause really bad idling....
Old Feb 8, 2004 | 04:52 AM
drift's Avatar
drift
Flaccid Member
diode != electrode
Old Mar 20, 2004 | 03:27 AM
Pawpawsmurph's Avatar
Pawpawsmurph
Pawpawsmurph
It's either your piston rings or your valve guides. Check both. This could also be the reason your idle is bad. Fix problem and check idle afterwards to see if that was the problem. If not, then change egr valve.
Old Mar 22, 2004 | 05:50 AM
Dreemer's Avatar
Dreemer
KOJ MOB PIM
The check engine light was on at that time too. I finally took it to the dealer and they put a new map sensor on. After driving 1300 miles to Kansas City and back, I'm gonna have to look at the spark plugs again. Seems like the vehicle is eating a little more gas.
Old Mar 22, 2004 | 07:50 AM
kiddo118's Avatar
kiddo118
Possible blown valve gasket or valve seals. Make sure engine oil is not overfilled.
Chrgsr96
6
Jul 21, 2003 08:30 PM
Civic_GSR
Engine Swaps, Tech & Tuning
6
Jun 25, 2003 07:27 AM
arowsell
May 12, 2003 08:47 AM
BenB
Accord
4
Dec 5, 2002 12:49 AM
showgunz
Aug 26, 2002 07:32 AM
