My car won't start!!!!
Heat can kill things like the main fuel relay, the fuel pump, and the coil. Start with the basics: Fuel, Spark, and Air. If you aren't getting spark, check the cap, rotor, coil, if you aren't getting fuel, then check/replace the main relay, if that doesn't fix it, check your fuel pump.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
As usual, 1stGenCRXer is right on. It sounds like a main relay.
When you turn the key to ON (not START), you should hear the fuel pump kick in. Listen for it at night, when it starts okay, so you'll you'll know what to listen for. Then, listen for it again during the day, when it doesn't start. If you DON'T hear it during the day, it's probably a bad main relay.
Geoffrey
92+ Civic/EL & Del Sol
4
Mar 9, 2008 04:06 PM
NamelessMC
7
Aug 2, 2007 07:10 PM
