o2 Sensor
Old Jan 14, 2004 | 06:29 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Default o2 Sensor
My friend had and HX engine with a 5-wire o2 sensor and we swapped in a JDM GSR with a 4-wire sensor. We can't get the CEL to go away and we were wondering how you need to wire it up to get the CEL to stop popping up.
Old Jan 14, 2004 | 06:31 PM
wambamcivic's Avatar
wambamcivic
Chester
yeah its the only thing keepin the CEL light on, all the others are fine, not throwin any other codes
Old Jan 16, 2004 | 08:34 AM
qtiger's Avatar
qtiger
Did you use your OEM harness or the GSR's harness?
Old Jan 16, 2004 | 12:00 PM
wambamcivic
Chester
yeah we used the stock HX harness
Old Jan 17, 2004 | 09:18 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
Have you checked to see what code the ecu is throwing? or is that where you came up with the o2 sensor...
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Jan 17, 2004 | 10:18 AM
qtiger's Avatar
qtiger
I don't have a 92-95 Civic electrical manual, unfortunately.
Go into a dealership and ask if you can look at their manuals... should tell you what pins are what right in there.
Old Jan 18, 2004 | 06:17 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Yes, we checked the ECU and came up with the o2 sensor. It was throwing 3 different ones, now it's down to just this one.
We were using the haynes manual, but I guess it's not the one you're talking about.
Old Jan 18, 2004 | 09:57 AM
wambamcivic
Chester
correction on the harness, we used the GSR harness
Old Jan 21, 2004 | 06:51 PM
wambamcivic
Chester
i have a problem now, just put a new TPS sensor on it, but it idles high in between changing gears, its stays at about 2k then drops down to about 1500 or 1k, im gonna go mess with it 2marrow, does anybody know what it could be?
Old Jan 21, 2004 | 07:28 PM
wambamcivic
Chester
we checked the throttle cable and adjusted it so what else could it be?
