checking vacuum
Old Jan 12, 2004 | 02:38 PM
s1ngle's Avatar
s1ngle
clutch slipping boost
Default checking vacuum
As related to my post in the Civic forum,
how do i check the vacuum system? I have read that it can be a cause of a lean running condition.
thanks for the help!
heres a link to my other thread, if you wanna help me there :thumbup:
https://www.honda-acura.net/forums/s...hreadid=118724
Old Jan 13, 2004 | 06:50 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
The vacuum system? Just buy a can of carb cleaner, have the engine held around 2500 RPM, and spray the hoses, intake manifold gasket and throttle body gasket a little at a time, listening for a change in RPM [~500 RPM]either up or down very suddenly.
-Harry
AIM: NDcissive
Old Jan 13, 2004 | 10:48 AM
s1ngle's Avatar
s1ngle
sounds messy
Old Jan 13, 2004 | 11:31 AM
1stGenCRXer
The carb cleaner evaporates pretty quickly. You'll actually be cleaning the lines as you spray them also
-Harry
AIM: NDcissive
Old Jan 13, 2004 | 11:37 AM
brtecson's Avatar
brtecson
pukimonster
carb cleaner is extremely corrosive, iirc. will there be any damage to the hoes?
Old Jan 13, 2004 | 11:45 AM
1stGenCRXer
The spray not the dip kind of carb cleaner.
The spray [aerosol can] is rubber and plastic safe, made to clean carbs still mounted on the engine. The dip will turn rubber into a mushy pile of tar.
-Harry
AIM: NDcissive
Old Jan 13, 2004 | 12:07 PM
s1ngle's Avatar
s1ngle
cool, thanks a lot man. I'll give it a try. How do i know which lines to spray?
Old Jan 13, 2004 | 01:07 PM
1stGenCRXer
Spray all of them, you're trying to find leaks, if you don't know which are leaking, then you don't know which to spray, do you?
-Harry
AIM: NDcissive
Old Jan 13, 2004 | 01:09 PM
vTeggy86's Avatar
vTeggy86
be careful though....i used to work at uhaul and ive seen 3 trucks go up in flames. but they use kinda a slow evap cleaner.
Old Jan 13, 2004 | 01:11 PM
1stGenCRXer
-Harry
AIM: NDcissive
