noob question, cutting hoses
Old Jan 10, 2004 | 04:13 PM
sspire's Avatar
sspire
Default noob question, cutting hoses
first is it ok and second should i just use an "exacto" knife? this is reffering to radiator hoses
Old Jan 10, 2004 | 09:59 PM
92integratypeR's Avatar
92integratypeR
ya its ok to do that man just make sure you cut it pretty straight. give yourself a little room too cuz i just cut my buddies radiator hose due to a wreck. i used a razor blade so good luck man.
Old Jan 11, 2004 | 04:06 PM
qtiger's Avatar
qtiger
I used tin snips. :dunno:
Whatever works.
Old Jan 14, 2004 | 11:32 AM
PHiZ's Avatar
PHiZ
BOOST GOD
I've had good luck with tools of this style:
http://airhosereels.com/hc01.html
Local hardware store probably has them, automotive goods store might let you borrow the store one, bring your hose to the store...
-PHiZ
Old Jan 15, 2004 | 11:41 PM
S2Kev's Avatar
S2Kev
I used a sharp pocket knife.
Old Jan 17, 2004 | 08:17 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
Cut it straight! Mine was cut crooked and I didn't realize it and my car kept over heating. I ended up replacing the hose becuase I noticed that there would be a little antifreeze on the cooling fan shroud. So far the new hose is working great.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Jan 21, 2004 | 06:06 AM
lingerbw's Avatar
lingerbw
I use a utility knife :dunno:
It seems to me that as long as you get a nice tight fit, and secure the clamp you should be ok.
