idle problem 95 delsol si
Old Dec 10, 2003 | 07:55 PM
sick_sol's Avatar
sick_sol
Default idle problem 95 delsol si
i have a idle problem its jumping between 800 rpm to 1300 rpm
the code came up 6 flashes (temp control sensor) changed the one on the block now it still dose the same thing but when i test for codes all i get is the check engine light staying on no flashes
now i found other sensor on the thermostat hosing is that the one that controls the computer and the i should have change.
thanks
sick_sol
Old Dec 11, 2003 | 06:08 AM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
The computer controls both sensors...the sensors don't control the computer. The computer reads from both, though... so if one doesn't fix the problem, maybe the other will.
On the other hand, your idling problem could be completely seperate from this termp control sensor issue.
Old Dec 11, 2003 | 07:32 AM
sxecrow's Avatar
sxecrow
Banned
I replied in the sol forum. Check the idle air control.
Old Dec 11, 2003 | 07:55 PM
sick_sol's Avatar
sick_sol
like what i have change my iac and it was not it what do u mean?
i change all my rad fulid as well.
thanks
Old Dec 12, 2003 | 04:37 PM
sxecrow's Avatar
sxecrow
Banned
thanks
I had the problem and it was the IAC, but the part was like $300 bucks and I was only a few months away from my swap. I just lived with it. If thats not it, I dont know what it is. Sorry I couldn't help more.
