Auto trany problem
Old Dec 8, 2003 | 10:40 PM
Integra GSlow's Avatar
Integra GSlow
Default Auto trany problem
I drive a 97 Integra GS and just recently I've been having problems with the transmission. Sometimes from a stop the car will run all the way upto redline before changing gears. Also when I'm on a hill and slightly floor it, it does the same thing. Most of the time I'm just driving casualy. I have to get off the gas before it'll change gears. Anybody have the slightest idea what's wrong?
Old Dec 9, 2003 | 10:32 AM
Integra GSlow
Not even a clue as to whats going on?
Old Dec 9, 2003 | 10:55 AM
jlude92's Avatar
jlude92
Gear ratio maybe??? i have an auto prelude and when i floor it, it will red line
Old Dec 9, 2003 | 02:35 PM
Integra GSlow
The thing is though I'm not flooring it. It'll just stay in first gear instead of going into second.
Old Dec 10, 2003 | 06:38 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
i think the ECU learns as to wut the driver's habit is
maybe it went a little crazy dat's all
reset the ECU by unplugging the battery or pull the fuse wait 15 minutes and see wut happens
this usually solves the problem
hope this helps:thumbup:
Old Dec 11, 2003 | 02:09 AM
Integra GSlow
you know I was thinking this same thing... I can only hope the problem is this small. I can't afford to fix this as is
Old Dec 11, 2003 | 06:23 PM
sirsasan's Avatar
sirsasan
Actually the problem you are having sounds more like a hydralic problem in the tranny.
Old Dec 12, 2003 | 07:21 PM
Kai's Avatar
Kai
Rotorphile.
Sounds like a failing transaxle to me. Honda automatics SUCK!
And no, the shift computer doesn't "learn" anything. It is programmed at the factory and will always act the same way unless something goes wrong.
Old Dec 14, 2003 | 08:09 AM
YeaItsAFourDoor's Avatar
YeaItsAFourDoor
..::-Free your mind-::..
Tranny slippage?
