Fluidyne Radiator Fitment
Old Dec 2, 2003 | 09:37 AM
SRD_DC2's Avatar
SRD_DC2
Default Fluidyne Radiator Fitment
I purchased a Fluidyne Radiator and the FAL radiator fan. However, on the radiator, there are brackets on only one side for the stock fan, and none for the a/c fan. I could not figure out a way to mount the FAL fan to the radiator itself as it is one peice.(doesnt fit very well either). My freind has told me that there are these little plastic things that u poke throught the radiator from the front, and u can mount the fan on from the back. Does anyone have a solution to this or know of this "plastic thing"
Old Dec 2, 2003 | 10:30 AM
h22avid's Avatar
h22avid
Sleeper...Creeper...
I'm not sure I follow you. If you have brackets on one side of the radiator for the fan, that is all you should have... just attach the fan there.
I have a FAL on a stock radiator and it didn't fit quite right either. The top holes lined up fine but the bottom ones I had to drill holes up a little higher and enlarge the cut out for the drain pug opening.... so long story short... a lot of times the FAL's don't fit quite right.
As far as your a/c fan is concerned, isn't your condensor seperate from the radiator and doesn;t the a/c fan attach to the condensor not the radiator.... at least that's how it is for my civic.
Old Dec 2, 2003 | 10:49 AM
SRD_DC2's Avatar
SRD_DC2
Oops, sorry, forgot to tell what car this was for, its a 95 integra.
