b16a1 into 96 honda civic ex need help!!
Old Nov 25, 2003 | 05:59 PM
esi2tsi's Avatar
esi2tsi
Default b16a1 into 96 honda civic ex need help!!
I have a 96 honda civic ex and i got a b16a1 really cheap didnt do the homework when i bought it and im stuck with it i have installed the motor made the mounts and have tried to install all the componets im trying to use the 96 ecu and stock injectors need help i have rewired the dist. from the b16a1 i have fuel and i have spark but no go i dont have the crank angle sensor hooked not sure what the problem is need help
Old Nov 26, 2003 | 08:50 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
Uh. You need to get a different ecu from an OBD1 honda. Like a integra gsr or a del sol vtec. How did you make the mounts? the original ones will work accept you need the mount from a 99 si for the rear, that connects at the bottom of the firewall. You're injectors should work okay. I'm not sure why you would have to rewire the distributor. Just a few wires in the harness.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
