B16 swap into a 94 hatch
Old Nov 25, 2003 | 02:55 AM
VtecApprentice's Avatar
VtecApprentice
Default B16 swap into a 94 hatch
Hi ALL ~!
did my search but got 8 pages of result but they do not really answer my questions
got a 94 hatch with a SOHC VTEC inside. thinking of doing a B16 swap. but i just do not know how difficult is the swap. i.e how much time this swap will take. and what a full swap consist of ? i.e tranny ? ? ECU ? ? engine block ? ? anymore parts to swap ? ?
ThankzZ :thumbup:
Old Nov 27, 2003 | 08:30 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
check
www.hondaswap.com
www.hybridgarage.com
www.c-speedracing.com
for more info.
The swap is easy, the hardest part is the wiring. Do a search in the 92+ section and the hybrid section. You will come up with a LOT of info, I promise.
Old Dec 1, 2003 | 01:59 PM
fish's Avatar
fish
if you are mechanically inclined the swap will be very easy to do its a direct bolt in swap the only thing is the engine harness will need to be switched for lhd if you buy a jdm b16 but you should be able to use your sohc vtec one the first swap my buddies and i did took a couple days just because we never really knew what all needed to be done and it was a learning process our best record to date on a swap is about 8 hours and thats dropping 2 motors and installing one. as for cost my b16 in my hatch cost me just shy of 3000 and that includes all the parts and everything on the hmo warranty
Old Dec 5, 2003 | 07:00 AM
VtecApprentice
YoOoO thankz dudE datz lotz of useful information
