Help
Old Nov 24, 2003 | 07:46 AM
94typerhb's Avatar
94typerhb
Default Help
my problem started when i cleaned my throtle body. i used the stp fuel injector cleaner. i didnt know that your suppose to wipe the inside, i just started to spray all the dirt into my manifold. after doing that, i tried to start my car (b16b motor). i couldnt get it to start until like a minute later, i just sat there cranking and finally itt started. well that wasnt the problem but it might have started from there, my problem is when i start my car now right before it ignites or starts it make a funny noise like: when u turn off your car the intakes makes that sucking noise or sounds like a "kirplunk", but this noise is coming from my engine when i start it. also after cleaning my manifold my car idles from 800rpm to 1500 rpm everytime i stop after moving. the only time it stops is if i sit at a stop sign for like 20 seconds. any help will be greatly appreciated.
Old Nov 24, 2003 | 08:48 AM
94typerhb's Avatar
94typerhb
i dont know if this helps but when i pump the brakes teh idle goes up? leak? also with that wierd noise sounds like a knock in my engine. what i did recently is changed my p28 w/o knock sensor to a p72 w/a knock sensor. i dont know if that my help. oh and my damn car keeps shocking me?
