losing horsepower
Old Nov 24, 2003 | 12:51 AM
wayne99integra's Avatar
wayne99integra
99Turbo GS-R
Default losing horsepower
I try to explain the best as I can, hope you guys understand.
theres something wrong with my gsr motor, its losing horsepower right now, really slow, I dont know why?? but I can feel looks like something block the intake or manifold or exhaust something...
Old Nov 24, 2003 | 02:29 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Clogged cat?
-PHiZ
Old Nov 24, 2003 | 04:09 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Are you secondaries opening?
Old Nov 24, 2003 | 05:26 PM
S2Kev's Avatar
S2Kev
Do a compression check.
Old Nov 26, 2003 | 09:50 AM
sphinx054's Avatar
sphinx054
do a compression test, cylinder leakage test, check the fuel pressure, and check the air fuel ratio. find what they should be and compair it to what you have. let me know
Old Nov 26, 2003 | 11:37 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Well as an electrical guy, I always think the problem is in my arena... so here are just a couple ideas.
How did you wire up for knock sensor, that will pull timing and you will feel a power loss.
I think an O2 sensor going bad would also cause a perceived power loss, so would fouling plugs. Check grounds.
What does everyone think. The thing is, when I troubleshoot, I start with "what was the last change that could have affected things" With a swap, it's easy, cause there are a lot of wiring changes.
Now, I'm just discussing so don't flame me. But as far as leakdown/compression testing, there is no way it will hurt, and it's great information. But I don't specifically see the cause that would produce that effect.
-PHiZ
