Ls/vtec=gsr?
Old Nov 22, 2003 | 10:27 PM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
Default Ls/vtec=gsr?
I've been doing searches on LS/VTEC lately and have gathered some info, but haven't had this question answered. If I built an LS/VTEC motor and a GSR motor with the same parts, would they be equal engines? Are the blocks identical?
Old Nov 22, 2003 | 10:30 PM
Snoopy's Avatar
Snoopy
been there done that
b18c1 block has oil squirters for each cylinder. installing those into a b18a/b block would seem like a bitch. and a b18c1 block has a block girdle. of course the cranks/rods would be different.
Old Nov 22, 2003 | 10:32 PM
jinx-mitchell
The Comic Guy
I knew Snoopy would help me out! So that means that the GSR motor would be slightly better than the LS/VTEC?
Old Nov 22, 2003 | 10:34 PM
Snoopy's Avatar
Snoopy
of course the gsr would be better than the lsvtec. you wont have the reliability issues with the b18c1 as you would with an lsvtec. but i have seen some impressive dyno sheets of "stock" lsvtec's.
Old Nov 22, 2003 | 10:37 PM
jinx-mitchell
The Comic Guy
I guess by better, I meant stronger. Does the LS block yield higher compression or anything?
Old Nov 22, 2003 | 10:39 PM
Snoopy's Avatar
Snoopy
stock form the ls block has lower compression than a gsr block. with an lsvtec, it would depend on what head you use if using stock block internals.
Old Nov 22, 2003 | 10:42 PM
jinx-mitchell
The Comic Guy
LS block, B18C1 head, CTR cams, CTR pistons, GSR crank
VS
GSR block, crank and head, CTR cams/pistons
= same power?
Old Nov 22, 2003 | 10:47 PM
Snoopy's Avatar
Snoopy
when you put it like that, i'd say yea the power would be similar
Old Nov 22, 2003 | 10:50 PM
jinx-mitchell
The Comic Guy
Thanks.
