air/fuel gauge Problem
Old Nov 18, 2003 | 02:23 AM
aktif's Avatar
aktif
Default air/fuel gauge Problem
hi i have a problem with air/fuel gauge
i can not install it to o2 censor
i have 1999 civic si h/b
pls help
Old Nov 18, 2003 | 05:37 AM
Kai's Avatar
Kai
Rotorphile.
What?
You need an O2 sensor to use the gauge. No sensor, gauge no worky.
Old Nov 18, 2003 | 01:07 PM
Oz`'s Avatar
Oz`
I am a friend of Aktif and i want to tell you. He wants to say that we have a 4 calbe o2 cencor but we cant setup with VAFC, it doesnt show completely. How can we fix it can you help us ?
Old Nov 18, 2003 | 07:16 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
UM??? little better english and we can answer you.
but this is just a wild guess at what your trying to say:
The V-AFC does NOT have an A/F gauge in it.
Also if you have the A/F gauge you hook it up to the WHITE wire on the o2 sensor.
Mason
Old Nov 19, 2003 | 12:26 AM
Oz`'s Avatar
Oz`
i have has VAFC and A/F but when i tie it to the white cable, it sends slow data so i cant do setings VAFC.i think it should have Wide Band o2 sensor if so do u have any idea ?
Old Nov 19, 2003 | 07:44 PM
Kai's Avatar
Kai
Rotorphile.
Do not tune off the stock O2 sensor, it is pathetically slow in response and doesn't give a very good reading anyway. All tuning should be left to a wideband.
VAFC's cannot read wideband O2 sensors though.
Old Nov 20, 2003 | 10:14 AM
hcar's Avatar
hcar
Default A/F Meter
Go to www.halmeter.com and see if you can get your info their.
Old Nov 21, 2003 | 09:18 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
I have both in my hatch with a b16a and they both work great. Allthough, I didn't install the vafc so I'm not sure what they had to deal with. Also it is OBD1 so that could be different too.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Nov 21, 2003 | 12:18 PM
Oz`'s Avatar
Oz`
i want Wide band sensor for AFR and put it on my manifold by opening a second hole for it..
Old Nov 21, 2003 | 12:24 PM
Oz`'s Avatar
Oz`
ihave OBD1 skunk2 ecu and its working too rich and i want to control it by vafc
