cleaning?
i just bought a gsr long block, and i took apart the headers. its really dirty in there and i was planning to take apart the head. i was wondering if there is way to clean it? some sort of spray? tools to use? can i use a rotozip to sand away the build up?
Ok kool. but is it ok to use a rotozip to sand down the the head where the header is, its alot of gunk. oh yeah if i [plan on letting my motor sit in the back yard should i drain out all the coolant?
Don't sand anything on the inside of the head unless you are a trained professional. If it doesn't come off with carb cleaner and a rag, it doesn't need to come off.
If you leave a motor in your back yard, it better be covered really good. And yes, drain the coolant.
as long as it is not to humid (I'm guessing Kali is far from humid) it should be OK.
You may want to get some heavyweight oil (20W50) or some MMO or something, and put a wee bit into each cylinder and turn it over by hand a couple times. That should get a nice oil layer on the cylinder walls and prevent pitting if it is going to sit a while.
