Mini Me swap
Old Oct 26, 2003 | 01:50 AM
S2Kev's Avatar
S2Kev
Default Mini Me swap
I'm considering a mini me swap with a z6 head because I can get a good deal on it. The following parts I can think of that I will be using for now are z6 head, z6 head gasket, z6 intake manifold and throttle body and an rpm switch to engage for vtec. I've done some research on this but I have a few questions.
I understand the a6 distributor will not fit on the z6 head without some fabrication or using the two side bolts and washers. I was wondering if it is possible to use a z6 distributor instead of the a6 distributor? I'm thinking it probably won't work.
I also understand that I should be using the z6 intake manifold on the z6 head because the a6 intake manifold ports are too small for the z6 head. I'm supposed to use the a6 fuel injectors right? Because the z6 injectors are higher impedance? Is the exhaust ports on the a6 exhaust manifold also too small for the z6 exhaust ports? And is it possible to use the z6 exhaust manifold with the a6 downpipes?
With the z6 head gasket, I hear the compression ratio will be around 10.1:1 or 10.4:1. Should I consider measuring the compression ratio myself? or should I just take those measurements into consideration and just figure out how to stop detonation? Do you think detonation will be a problem even if I use the z6 fuel pressure regulator? I read with the a6 distributor on the z6 head, there is not enough room for adjusting ignition timing.
I'm trying to do this swap rather cheaply so I'm trying to make everything work without buying anything thats too expensive. I will have more questions but I guess they will come later. Your help is greatly appreciated. Thanks.
Old Nov 13, 2003 | 08:01 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
ok.. i did this swap already on my hatchie!!!
- a6 bottom end/z6 head, the a6 distributor will either be advanced a little or retarded A LOT
- you can only use the top dist. bolt and the bolt closest to the front end
- you don't need the z6 intake mani, its just recommended for more air flow = more hp
- you can use the z6 distributor, just have to re-wire the distributor clips so you can use it (a6 distributor plugs on the z6 distributor)
- you will have 9.9:1 CR if you use the z6 headgasket if you use the a6 you will have 9.7:1 CR
- you CAN use the RPM activated switch but i wouldn't recommend it, get a Apexi V-AFC or Fields VTEC controller
- and use the same header that you would use with the a6, z6 header flange is differenet than the a6 so the a6 downpipe won't bolt up properly.
one last thing: BE SURE TO TAKE OUT THE OIL CONTROL JET IN THE BLOCK!!!!! OR ELSE VTEC WON'T ENGAGE PROPERLY WHICH THE ENGINE WON'T BE AS COOL!
anything more? AIM me: Team DraZtiK
