compression test on ls b18b
Old Oct 17, 2003 | 10:57 PM
sol_1320's Avatar
sol_1320
Default compression test on ls b18b
Is 175 across good or bad
Old Oct 18, 2003 | 07:44 AM
DanM's Avatar
DanM
That's just fine. It's not stellar, but it's pretty normal for an engine with some miles and years on it.
Old Oct 18, 2003 | 07:33 PM
sol_1320's Avatar
sol_1320
That makes me feel a little better so could I still go turbo or not. I do plan on getting it tune with turbo
Thanks
Old Oct 18, 2003 | 07:54 PM
DanM's Avatar
DanM
Well, it's not such a simple question. You can't just look at 4 numbers and say yes, your engine will hold it, or no, it'll blow up.
What I can say is this - your compression looks GOOD. If you run a reasonable level of boost (say, up to 8lbs), you *shouldn't* have much trouble holding it. I mean, heck, your engine could blow up tomorrow, for all I know. But there's nothing in those numbers that suggests that you have a major problem. Does that make any sense?
I will also say that a good tune is ESSENTIAL. If you're not properly tuned, and you start leaning out under boost, or something like that, your chances of blowing up tomorrow just went up by a LOT. Proper fuel management is particularly essential to running a turbo.
But if you're properly tuned and running well, you should be just fine.
Old Oct 18, 2003 | 10:24 PM
sol_1320's Avatar
sol_1320
thanks
Old Oct 24, 2003 | 12:41 PM
sphinx054's Avatar
sphinx054
its good. thats about what hondas run.
Old Oct 25, 2003 | 11:53 AM
LateApex's Avatar
LateApex
Track Day Club
Just a note that the F20C runs in the 220-245 psi range. 175 on that motor would not be a happy compression test.
