Simple Wiring Q
Old Jul 18, 2002 | 05:37 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Default Simple Wiring Q
What wire is this (knock sensor or VTEC)?
B18C1 Swap into '95 Civic DX
Old Jul 19, 2002 | 09:18 AM
v4lu3s's Avatar
v4lu3s
if it is red with a blue stripe it SHOULD be knock sensor. you can also check at the knock sensor plug with a continuity tester...by making sure that that wire and the plug have continuity.
Old Jul 19, 2002 | 11:31 AM
westcoaststyle
I don't have a tester. If you look at the harness plug and the position of the wire, isn't it knock sensor. I just want to be sure before I start crimping connectors on the wires I've added.
Thanks!
Old Jul 21, 2002 | 10:44 AM
westcoaststyle
Ok, I broke down and got a tester like you said. I traced the wire back to that piece you and I were talking about before:
Tell me what it is again???? Thanks man!
Old Jul 23, 2002 | 05:39 PM
kinghawk's Avatar
kinghawk
purge valve
Old Jul 23, 2002 | 05:41 PM
westcoaststyle
Evap purge?
So what position in the ECU should it go to?
delheat
Accord
Feb 11, 2008 08:33 AM
tvon
Accord
22
Nov 8, 2004 06:15 AM
kenton
Engine Swaps, Tech & Tuning
5
Sep 13, 2004 07:40 PM
Dimi
4
Sep 4, 2003 09:17 PM
