Need help please! Won`t rev up pass 5K rpm!!!
Originally posted by djcrx
*Like the topic says, It`s just doesn`t want to rev up all the way to redline. it bogs on 5K and it stays there. What`s wrong with my car?
* Helpful hints from my 91 CRX Si:
- it runs good
- No check engine light
- Just tuned up and Timing is dead on
* Things I have doubt on:
- PM6 ecu not sure about the chip tho
- 92 Civic DX 1.5 head with 1.5 DX Dizzy
****I know there`s a lot of peeps here that has some information about this problem. Please help. Thanx in advance.
- it runs good
I'm glad it's not vtec, it makes troubleshooting a little easier at least...
Th PM6 is an OBD0 computer, and you have an OBD1 engine? Care to explain a little more about the wiring swap
My next instinct kinda tells me it's a sensor on the distributor that is wired squirrely. And what qtiger said is DEAD ON about performance roms disabling diagnostics.
Open up the ecu, and see if there are any 42 pin chips with like a sticker over them, that'll tell you if it is fact chipped.
But yeah, more info on what's up with the wiring.
-PHiZ
-PHiZ
-PHiZ
-PHiZ
92 1.5 dx head
91 1.6 Si bottom/ block
*PM6 ECU (I dunno if it is 42 pins or 28
*As far as wiring I have no clue
can somebody please tell tell what to look for on the dizzy.
*I`m still having this problem please help ASAP
I change the ECU to a stock ECU and the problem (5K rev.) is still there
*How would I know i have a bad dizzy?
*Connection on the dizzy diagram please.
