Advanced Timing Kit?
Old Jul 18, 2002 | 03:32 PM
xbladr's Avatar
xbladr
Default Advanced Timing Kit?
what the hell is this http://cgi.ebay.com/ebaymotors/ws/eB...ndexURL=0&rd=1
and how could this actually work? can someone please explain why this would even help to me it looks like a gimmick
Old Jul 18, 2002 | 03:39 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
I've seen this before.
What it does is tells your car that you're seeing colder air than you really are, so the computer compensates by spraying more fuel into the cylinders and keeps the timing advanced instead of allowing the normal conservative ECU controlled timing to stay in effect.
Bottom line: you'll burn more gas, but you won't really get the claimed power, the only way to safely and consistantly squeeze more power out of your setup would be to get an honest fuel computer instead of a little box that lies to your engine and claims power. The only real truth I saw in that was "watch your 1/4 times increase". Now tell me, who really wants their times to increase?
-Harry
AIM: NDcissive
Old Jul 18, 2002 | 07:57 PM
Charged-GSR's Avatar
Charged-GSR
you can gain a little hp with the unit but poor fuel quality will cause pinging and that can kill your engine.
I dont recommend this type of upgrade.
put it this way you get what you pay for. spend the cash and get some real ponys.
Old Jul 25, 2002 | 11:01 PM
SR20DESam's Avatar
SR20DESam
An easier way to pick up "free hp" per se is to just bump your timing up a few degrees and run higher octane gas.
Dynos on the SR20DE show that with a bump from like 12 degrees to 19 degrees produces almost 5WHP.
Only needs 91 octane too.
Sam
Old Jul 26, 2002 | 01:26 AM
1stGenCRXer
Late model hondas are electronically restricted to 18 degrees of timing by the ECU. This "upgrade" tricks the ECU into allowing more timing, and makes up for the overkill by drowning the engine in gas to avoid ignition knocking.
Again, worthless.
Old Jul 26, 2002 | 02:19 AM
MikeSarr_GSR's Avatar
MikeSarr_GSR
ignition timing advance is a good way to wear your internals also if you go too far...
Old Jul 26, 2002 | 04:53 AM
1stGenCRXer
If you go too far you also lose performance. There is no magic number of degrees for performance on any engine, just as no two engines perform exactly the same. For example, my engine is running 34 degrees total advance, and 20 degrees static, try running that on a B16 and it would probably never start
2ltrEGhatch
6
Apr 8, 2009 09:21 PM
vti-crx
CRX & Pre 92 Civic
5
Jul 11, 2004 06:13 AM
onthekeyboard
CRX & Pre 92 Civic
20
Aug 12, 2003 02:23 PM
Kai
Engine Swaps, Tech & Tuning
6
Jul 4, 2003 03:53 PM
