Need Help Badly, transmission problems
Old Oct 9, 2003 | 11:27 PM
jeffro's Avatar
jeffro
Default Need Help Badly, transmission problems
OK I just bought a 1995 Civic EX that did not have a tranny in it. I bought a tranny for it, but it had a big whine to it, and was told the tranny was no good. So I bought another tranny for it, and it does the same thing.
this is what I have done:
new clutch
pressure plate
throwout bearing
resurfaced flywheel
I dont know if maybe the throwout is bad or what, but it was brand new. Is it possible to put a clutch in backwards, or put a throwout bearing in wrong? I have spent all day today messing with it, and it is just irritating the crap out of me now. Is there any place that has pictures of the way a clutch and a throw out bearing are supposed to look when installing them? I mean it looks like they each only go on one way to me, but same whining noise, what are the possibilites that i got 2 bad transmissions? the second one came from an import shop, and it only came out because of a motor swap.
somone please help me quick I want to drive the damn car, its my only car right now.
thanks a ton,
Jef
Old Oct 10, 2003 | 04:26 PM
AwwsChwA's Avatar
AwwsChwA
Possibility of getting two USED transmissions that are both bad is pretty high. First thing to fail in a SOHC honda gearbox is the input shaft bearings. Try this...with your car idling, transmission in neutral...push in the clutch and hold it there for 5 seconds or so. Then let it pop up. If you hear a distinct hiss or whirring sound right when the clutch engages, the input shaft bearings are bad. Now, Push the clutch in again. If that same sound goes away when the clutch is disengaged, that verifies that it's the input shaft bearings.
You can detect bad countershaft and final drive bearings while you're driving the car. You'll hear the same kind of buzzing, hissing or whining sound while the car is in gear and driving, and it will be louder in certain gears depending on which bearings are bad. For example, my last transmission had a failing countershaft bearing on the far end by 5th gear. I could tell because, as soon as I shifted into 3rd gear, I heard a faint buzz. 4th gear, the buzz got louder. 5th gear, I could hear it over the stereo.
Unfortunately there's no way to detect these things until the transmission is installed. If you've gotten two bad trannies from the same shop, I'd say its time to find a new supplier.
