launching
ok just got back to the track and what a grip difference with drag radiel i ran 4 times 3 of them i didn't come out with enough power so the car bogged out the best time i ran is a 9.57 in the 8th my reaction was 636 i be leave i clocked in at 76 or 77 that time i didn't bog out but i did over rev alittle anyone with some help integra ls greddy kit and drag radials what can i do to get better times i do deep stage and leave on the last umber anything else launching
Apathy Kills
Moved to Drag Strip.
been there done that
you need to drop them to 10psi and work your way up and down from there. remember to do a burnout. not a crazy long one, just a quick one to heat up the tires and clean them off.
you're not taking full advantage of the DR's if you leave them at the stock psi. air them down so you get a bigger contact patch and so the sidewalls have some room to flex.
i just posted in the other section but im launching at 4500 and shifting at 6500. i started on 20psi in the tires and i spun them through 3rd. i got down to about 8.5lbs and they were great. the last runs i was working on my launching and launched at revlimit and shook the tires and ripped out a 1.6 60' but missed 2nd cause it came to fast but ill try some more later..
