Good Launch RPM
Originally Posted by gingas
I just figured the 185's would be better besides I see a rack of people using their steelies up front.That's all. What motor do you have,car & times you've done.
$5 says they are running 205's too.
What motor did you have all motor & what kind of car you have. I'll problably launch around 3-3.5 rpm.Hopefully I should get a mid 14 hopefully.Did you remove your spare tire as well. I figured I'll take as much useless weight out to help.Every little bit of weight removed helps. Thanks for the info.
98 ITR will full interior including spare. it had I/h/testpipe/exhaust/clutch/flywheel/vafc
