Drag Strip From the staging lanes to the finish line, this is the spot for on-track drag racing discussion.
how to launch?
Old May 23, 2004 | 03:46 PM
Mackenzie C's Avatar
Mackenzie C
Default how to launch?
how do you launch off the line?
Old May 23, 2004 | 07:42 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Bounce it off the rev limiter and drop the clutch.
Old May 25, 2004 | 08:58 PM
wedley2's Avatar
wedley2
bboy Wesley West
lol, best way.
Old May 26, 2004 | 05:58 AM
twin3037's Avatar
twin3037
figure the right rpm so that the tires peel enough that the engine doesn't bog down but no more then that
Old May 26, 2004 | 08:58 AM
importkustoms00's Avatar
importkustoms00
Korean DOOD
i have a stock 95 civic when should i launch?
Old May 26, 2004 | 06:25 PM
wedley2's Avatar
wedley2
bboy Wesley West
trial and error, my friend
Old May 26, 2004 | 07:16 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
When the light turns green.
Old May 26, 2004 | 07:28 PM
sensei's Avatar
sensei
get out there and learn. experiment with rpm, tire pressure, and clutch modulation.
Then analyze your timeslip, and do it again. After a few years you should get the hang of it...btw R compound tires help too...
Old Jun 27, 2004 | 01:32 AM
DavE96GsR's Avatar
DavE96GsR
well...i ave a 96 gsr, first year havin it and first year at the local strip...
i usually pull around .4XX;s off the line...sometimes .03..
what i do is try to go at the light before green which is .500 before green turns on..
im still experimenting with tire pressure and rpm's tho, i cant get a great start seeing as i usually spin out too much... good luck
Old Jul 2, 2004 | 09:50 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
I dont worry about reaction times. Usually mine is around .7 but goes up to 1.3 secs.
