Drag Strip From the staging lanes to the finish line, this is the spot for on-track drag racing discussion.
could i take these guys?
Old Feb 5, 2004 | 04:36 PM
fastrnuGSR's Avatar
fastrnuGSR
Default could i take these guys?
hey i have a stock 95 GSR. this guy wants to race me in his Jetta. its like 2001 and its a VR6. could i take him? he says he has like 210 hp, but that his car is really heavy. also, its auto.
also a stock 2002 IS 300. its auto but has the paddle shifters.
could i take these people?
Old Feb 5, 2004 | 04:59 PM
Nathan1234's Avatar
Nathan1234
Domestic Driving Asshole
Your car is capable of destroying all of them (stock for stock). The jetta by quite a bit.
Now, a question for you:
Why do you guys come here and ask this shit when you could look it up yourself, or (imagine this) quit being a pussy and just race.
Old Feb 5, 2004 | 05:44 PM
03accordcoupe's Avatar
03accordcoupe
^New car...2003 BMW 330ci
You will beat the Jetta, and lose to the IS300...Jetta VR6's are mid 15 stock if I remember correctly(theres someone on here with a VR6...he'll be able to give a more definitive answer I'd imagine)...and the IS300 can pretty easily hit 15.0 stock, not sure if thats with the manual or paddle tranny though.
Old Feb 5, 2004 | 05:54 PM
Nathan1234's Avatar
Nathan1234
Yeah, you're right. :thumbup: I mis-read the 15.0 as 16.0 (my bad). I think the lexus would win. I also think the best way to find out is to race.
Old Feb 5, 2004 | 06:57 PM
senseiturtle's Avatar
senseiturtle
euro trash
If he's an auto VR6, you should win it. With both cars having 5-speeds, it comes down to more of a driver's race. I ticked off 15.4 with an intake (5-spd). Not wonderful, but not that horrible either.
Jetta VR6's between 99.5-02.5 come with a listed 174 cHP, but that number is misleading. VW under-rates them a bit from the factory, with many stock VR6's dyno'ing near 165 whp and 178 ft-lbs. 3050 lbs is a typical curb weight. The gearing is very tall, 1st - 40mph, 2nd- ~70, 3rd- high 90's.
----------------here's where the guessing begins-------------------
So... as i've said... if he was a 5-speed, he'd pull you off the line, and you'd make up the ground inch by inch on the high end (with good driving). Since he's an auto, you'll probably launch somewhat evenly, and you'll pull him a bit harder at the high end.
The IS300 will give you a much tougher race. Bring your A-game and hope he bogs or otherwise screws up, because you're at a fairly signifigant torque and power disadvantage, as well as RWD. You're likely to get edged out on that one.
so, there ya'll go.. a semi-comprehensive guide to jettas. Just stay away from a VR6 with boost... most tick off 12's with no problem, and most fairly well-built ones are in the 11's.
Old Feb 5, 2004 | 07:08 PM
Fast-Ford's Avatar
Fast-Ford
Loves Nascar, NHRA & SCCA
Don't assume just because a car is heavier that it is slower.......always check out the torque numbers first. often times, powerful cars need to be heavier for strength and support purposes.
Old Feb 6, 2004 | 07:57 AM
hyperlite's Avatar
hyperlite
auto is300's are slow as hell i know that
Old Feb 11, 2004 | 12:19 PM
Tobra's Avatar
Tobra
I have smoked a few IS 300's all autos, none close. You will own the jetta too, auto trannys slow little cars down a lot. That VR 6 is a torque producing motor, but so sad, the tranny will suck a lot of it up. Either car with a standard would be close
Old Feb 11, 2004 | 06:05 PM
b16hatch's Avatar
b16hatch
if he is an auto u should win. I dunno about the IS300 though, what i do is my friends best stock 1/4 time with a 95 GSR , after 10 runs , was a 15.6@87 mph , and his worst a 16.1@88 mph ( he spun to much :awais: )
Old Feb 11, 2004 | 06:49 PM
brtecson's Avatar
brtecson
pukimonster
slow comapared to what?
