Installing Lowering Springs
Old Oct 30, 2003 | 07:14 AM
h22avid's Avatar
h22avid
Sleeper...Creeper...
Originally posted by Microbrewa
ok sorry but i FINALLY started to do the back end yesturday.
i loosened up the top of the strut bolts, then my directions said loosen the bolt at the bottom of the strut... so i went down there and tried to loosen it
i tried over and over, used pipes for leverage, had about 3 guys try it....and it would NOT budge...we put WD-40 on it...everything. I think its just about completely stripped now and i cant get it out....what should i do? the other side, the bolt just came right out...
If i went to a mechaninc to take the bolt out...would it be unsafe to drive the car back home with it loosened/out? i figured it owuld be but i wanted to know for sure.
were you turning the bolt the right way... righty tighty.. lefty loosey? It should comeright out unless it was torqued down by the HULK
I wouldn't drive it with the bolt loose. A shop would probably have to use a torch to heat it up and get it out. A strut is not that labor intensive so while their down there I would just have them swap it out for you. If they won't or it costs too much, have them get the bolt out then roll it out in the parking lot and do it yourself. The rears are really easy and should only take like ten minutes to do.
Old Dec 1, 2005 | 08:58 AM
ek9project's Avatar
ek9project
Default Eibach sportline springs INSTALLED
hey i need ur opinon guys i bought Eibach sportline springs and i got them installed for 300$bucks. Is that good? or too much or cheap?
Old May 15, 2006 | 04:11 PM
enomix's Avatar
enomix
yeah got it done at a shop and charged me out the ass but i had the rear bushings replaced to
Old Jun 5, 2006 | 05:49 PM
earlhickey13's Avatar
earlhickey13
yeah its scary to first few times.But now i dont even use a spring compressor I got a method and dont even worry about it now.But hey if you think that is scary do a jdm conversion with no insrtuctons and guessing on most of it.Its kind of scary when you have the whole front end ripped off and not sure if your doing it right.But I say go for you have to learn sometime.
Old Jun 14, 2006 | 01:12 AM
greasemonky50's Avatar
greasemonky50
spring compressors are available at autozone for like 30 bucks. ill will start doing my own spring and shock install it will take forever cuz its my first time. but i will feel a lot better knowing im doing my own job. cuz the installation prices are steep. working on your own car is like sex it feels good begining to end. after that light up a cig.
Old Jul 23, 2006 | 05:47 PM
quik's Avatar
quik
1337 h4x0r
this is the most fantastic thing that i have heard in my entire life.
Old Jul 24, 2006 | 10:34 AM
I_S_R's Avatar
I_S_R
http://videos.streetfire.net/search/...96D5A32764.htm go to this website it actually shows how to install lowring springs, on video!!!! (better than reading)
Old Sep 5, 2006 | 07:08 AM
qui004's Avatar
qui004
Originally Posted by Microbrewa
how much is a spring compressor, where could i find one?
i found on this site, it shows how to take springs off without a spring compressor http://www.deepstaged.net/stock_spri...ithout_spr.htm
hey you can get a compressor from discountautoparts for like a $50 deposit.
Old Sep 5, 2006 | 09:25 AM
Or you can buy one for 20 bucks at Autozone h:
Old Nov 17, 2006 | 02:32 PM
dr_jekal01's Avatar
dr_jekal01
hey I was doing my springs for my 95 integra, they are adjustable with the aluminum tube as an adjuster, I got these rubber o-rings that came with it and in different thickness, does any body know what I gotta do with them? and also I removed the dust shield off the strut cause it wont fit through the aluminum adjuster, is it all right leaving them out or is there a way to fit it in? would some get to me asap on this, my car is on jack stands right now and I need my ride up and going.
here is how they look like
