H22A swap, where is knock sensor?
Old Sep 24, 2003 | 12:01 AM
Hzipp's Avatar
Hzipp
Default H22A swap, where is knock sensor?
Hello from Russia.
My swap H22A into 94 Accord Coupe is done. But I can't find where is knock sensor on engine, so I can't connect to it wire. Please help, if your have photo of rear side of engine with this f***ng sensor. Engine already installed, so there is very dark at its rear side. :-(
Thanks.
Old Sep 24, 2003 | 06:54 AM
BustedLX's Avatar
BustedLX
Rice Rocket
The knock sensor is right below the intake manifold on top of the oil filter. It's got a black one pin OBD-1 connector. Directly below it under the oil filter is another sensor that has a screw on ring connector. On your F series engine that sensor was where the knock sensor now is.
