Door panel removal trouble
Old Sep 22, 2003 | 12:49 PM
95TEGGY's Avatar
95TEGGY
Default Door panel removal trouble
Hey guys, i got a 95 Integra. Im trying to remove the door panels but its seems to be stuck or something. I remove all three of the necessary screws. The coin holder. The lock and door handle, and the one right under the side view mirror. A buddy said that all he did after that is pull it up and then to the left and it poppes out. Mine however feels like its glued or something. It wont move anywhere. Has anyone had this problem before. Thanks
Old Sep 25, 2003 | 08:42 AM
all motor 91ef's Avatar
all motor 91ef
USDM spec
yours should just pull up and pop out. Check the wire that is connected to the door locks. It might have just gotten shortened is not allowing you to pull it out.
Old Sep 25, 2003 | 09:16 AM
95TEGGY's Avatar
95TEGGY
thanks i already took it out
Old Oct 16, 2003 | 09:05 PM
oldskool's Avatar
oldskool
gotta rip it off and lift it, but you probably know that by now ... good job.
