removing a 96-00 civic dash
Old Sep 2, 2003 | 07:24 AM
source1tx's Avatar
source1tx
Default removing a 96-00 civic dash
where do i start. where do i disable the airbags. im removing my own dash to save on some of the labor cost to have my interior fiberglassed and painted. should i attempt this task or just let my shop do it. anyhelp would be great
Old Sep 2, 2003 | 05:55 PM
98WhtCivicEx's Avatar
98WhtCivicEx
^^That's Me!^^
Default Re: removing a 96-00 civic dash
Well..if you have a civic...like I do...then its pretty easy. I removed my whole dash to put reverse glow dash lights in. Basically you unscrew the screws under your steering wheel..that hold th top and bottom plastic pieces together around your wheel. then put the two out and together. Its a little byatch to get them apart but if i remember right they just snap together as many of the things on a honda do. after you get those off, then you will see a plastic piece infront of your dasj...right up under there, there should be 2 screws holding it in...just unscrew the two and then you have to pull the top part down and out toward the wheel. that will come out and then you will see the whole cluster. Im not sure if this is what your asking how to do...if your trying to get to your cluster in your dash but if you are then good. but when you see the cluster you should see the screws holding it in. basically unscrew them and pull it out. unplug the 2 or 3 plugs and you have your dash apart. Hopefully that answered your question. If it didn't...then next time be more specific about what you want...cause if this isn't...it was a waste of typing...damnit :madfawk:
