Civic 92-95: How to install gauges?
Old Sep 1, 2003 | 07:57 AM
loodboi's Avatar
loodboi
هونده بريلود
Default Civic 92-95: How to install gauges?
Hi guys!
How do i take out the noodles from the gauge cluster, to put the new gauges. And then put on the noodles..
Pls help!
Old Sep 1, 2003 | 02:05 PM
Technodigifreak's Avatar
Technodigifreak
Hot-Modder
pick up, the haynes repair manual for your civic, and the haynes electrical repair book
it tells you everything you need to know
Old Sep 1, 2003 | 09:58 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
if you are talking about "needles",..then DO NOT remove the needles,..you have to slide the gauge faces over the needs,...becareful not to break the needles,...becasue you will be screwed and would have to buy a new cluster,...and if you take off your needles,..you will have to buy a new cluster
Old Sep 2, 2003 | 03:00 AM
loodboi's Avatar
loodboi
هونده بريلود
hehehe yes i ment the needles..
ok thank u..i will not remove 'em
