Transmission removal
Old Aug 10, 2003 | 04:17 PM
erik99's Avatar
erik99
Default Transmission removal
I'm getting ready to do a clutch in my '89 Integra. How necessary is a true transmission jack? Any other ghetto methods I should know about for removing/lowering the trans.?
Thanks,
Erik
Old Aug 15, 2003 | 07:16 AM
turbovic's Avatar
turbovic
use a regular jack to support it its not completely necessary so long as u have some sort of good support for it and keep it stable
Old Aug 15, 2003 | 08:29 AM
prostang460's Avatar
prostang460
I just had the transmission out of my civic on wednesday. I put the car on four stands and took the transmission out and put it in without a jack, it only weighs 50 or 60 lbs.
If that doesn't work for you, a regular floor jack will work.
Old Aug 19, 2003 | 09:16 AM
JimBlake's Avatar
JimBlake
Looks like the special thing about a tranny jack is that it has a big wide tray on top. If you use a normal jack, you just get down there & guide the transmission down so it doesn't topple.
Old Sep 4, 2003 | 01:42 PM
jung4g's Avatar
jung4g
Asianalize your car
I do it by hand like prostang460. I just unbolt everything, grab the mount and wiggle it off, and then lower to the ground by hand. Putting it back in, I just slid the tranny under, lifted it up with one arm, and had a buddy help slide it into place, pretty simple.
Jung
Old Sep 4, 2003 | 02:41 PM
erik99's Avatar
erik99
Thansk all, I got it:
http://www.northatlantaplasticsurger...t.html#latest2
