Removing paint from plastic pieces
Old Jul 17, 2003 | 04:43 PM
jusofat69's Avatar
jusofat69
Default Removing paint from plastic pieces
Hi,
I just bought a 95 civic hatch in red. The previous owner had painted the interior platic vents/door handles/ dash piece behind wheel a bright shinny red. The color is killing me. Would I be able to maybe soak the pieces in paint thinner and get the paint off or Do I have to buy all new pieces. He said the paint was just regular spray can paint.
Adam
Old Jul 19, 2003 | 03:27 PM
Samson's Avatar
Samson
chris is the devil
why not redo it all gloss black or something... black pearl looks nice.
Old Jul 13, 2004 | 07:46 PM
lkailburn's Avatar
lkailburn
college kid
no one has a fix for this? i bought a center console arm rest but its painted black. it originally was the same color as my plastics
Old Jul 13, 2004 | 10:59 PM
brake fluid.... a little messy though....onl;y on small things too... big things its a bit tricky
Old Jul 14, 2004 | 04:22 AM
lkailburn's Avatar
lkailburn
college kid
^^ what makes big things tricky? do i run the risk of ruining the original color? cuz the original color is the same as my plastics, soo i just need to get the black paint off. i'll try the brake fluid on a small corner or something and see what happens.
Old Jul 14, 2004 | 05:00 PM
ExiledinIN's Avatar
ExiledinIN
I thought there was a FAQ on honda-tech, and I was right. Here you go.
http://honda-tech.com/zerothread?id=598255
Old Jul 15, 2004 | 04:22 AM
lkailburn's Avatar
lkailburn
college kid
cool thanks man. i'll give that a try
Old Jul 17, 2004 | 02:44 PM
StGeorgeHB's Avatar
StGeorgeHB
/\ /\ Wow, what a waste of time.
Go to wal-mart or checker/autozone and buy some PEELER.
This aresol product removes paint and SHOULD not (test first!) damage any plastic. I have cleaned up several interiors/rims/dashes/mufflers etc with this product.
But remember to try not to breathe it in.
Old Jul 17, 2004 | 06:21 PM
lkailburn's Avatar
lkailburn
college kid
^^^ i don't see how using a harsh chemical thats 1: bad to breath and 2: runs the risk of ruining the stock paint is better than using something safe and "tried an tru" ....
i think i'll use the brake fluid method. i'll just let it soak and keep switching it around every once and a while as i'm working on other projects.
Old Jul 17, 2004 | 07:26 PM
StGeorgeHB's Avatar
StGeorgeHB
Ok, for one, there is no "stock paint" on plastic parts. 2, yes it is bad for you inhale but no more than spray paint, ie DO IT OUTSIDE and is probably a lot safer/cleaner than getting brake fluid all over the place.
Chemical strippers are more "tried and true" then soaking shit in brake fluid. And plus they take half the time.
