Where to come thru firewall for amp wire?
Old Jun 9, 2003 | 09:02 AM
RednasSir's Avatar
RednasSir
Default Where to come thru firewall for amp wire?!?
Where is a good location to come thru the firewall on a 2000 Civic EX for 4 gauge amplifier wiring?? Is there a pre-existing location or will I have to drill?
Thanks
Old Jun 9, 2003 | 10:25 AM
crxb16er's Avatar
crxb16er
you can try to cram it thru one of the grommets that are already there, if not u can drill a hole and get a rubber peice to install the wire thru, both ways are simple, they dont have any holes left open ready to receive a big wire like that. ur gonna have to cram it in or make a new one.
Old Jun 9, 2003 | 10:34 AM
RednasSir's Avatar
RednasSir
Thanks! I thought I saw some place on the passenger side to come thru. Appreciate the help.
Old Jun 9, 2003 | 12:22 PM
pnthr30's Avatar
pnthr30
Default through fire wall
I know this if for an Integra and you have a civic, but I thought it might help you out anyways.
page 6 of this article should help you out - hopefully.
http://www.team-integra.net/sections...?ArticleID=330
Otherwise, here is an post from a few days ago.........
https://www.honda-acura.net/forums/s...threadid=58225
Try a search on it, I am sure that something will come up
Old Jun 14, 2003 | 08:43 PM
FromTheBottom's Avatar
FromTheBottom
Driver of Trains
i went through the existing grommet on the passenger side, directly below the glove compartment, and pulled the wire under the interior side panels from there. i like that spot due to proximity to the battery.
Old Jun 16, 2003 | 04:45 AM
RednasSir's Avatar
RednasSir
That is the grommet that I am seeing, too. I didn't know if anyone had used it (didn't know exactally where it went). Glad to hear that it worked for you. Will definately use that place since it seems the easiest.
