Painting brake calipers
Old Apr 12, 2003 | 11:23 AM
Spyfunkr's Avatar
Spyfunkr
Default Painting brake calipers
I have some remanufactured front calipers about a year old. They rusted rather quickly, ive sanded most of that off.
Do I need to primer them before painting? Im using high heat paint.
Thanks, Spy
Old Apr 15, 2003 | 03:38 PM
crxb16er's Avatar
crxb16er
well u dont have to but more than likely the brake dust in there will cover them over quickly so u may want to primer them sand down the primer till smooth and then paint and seal with some clear coat that can stand the temperature down there cuz i just painted mine and the were nice and blackish in about a month, but then again i dont really care about it so i just painted over the crud again, if they were smooth i'm sure they wouldnt hold so much crap
Old Apr 19, 2003 | 08:50 PM
MikeR's Avatar
MikeR
i tried cleaning with solvent and using heat paint and it did no better than just priming and painting with regular paint,
Old May 12, 2003 | 08:39 AM
OffDuty's Avatar
OffDuty
Gotta do it right.. This is excellent stuff. I have used it on two cars with great results:
http://www.tirerack.com/brakes/g2/caliper_paint.jsp
Old Jul 1, 2003 | 10:18 PM
Technodigifreak's Avatar
Technodigifreak
Hot-Modder
great stuff, and if your going to do it, do it right and put ceramic pads on at the same time, no squeaks ever and virtually no visible brake dust!
Old Sep 21, 2003 | 09:26 PM
toyman99's Avatar
toyman99
I use brake cleaner on my parts
Let it dry
Sanded it down
Use brake cleaner again
Ran warm water
Let it dry
and it came out perfect. Took everything off.
I used p21s wheel cleaner in GEL form, the liquid version runs too quickly.
