Brake Pad DIY
Old Mar 9, 2003 | 10:07 AM
RandyP's Avatar
RandyP
Default Brake job
I am trying to replace the back brake pads on my 2000 Accord and I am having a problem getting thee piston pushed back into the caliper. I have loosened the bleeder valve and tried removing the hose bolt and I still cannot get it pushed back with moderate force. Is there some trick to this? I have never had this problem before with other vehicles.
Old Mar 9, 2003 | 11:41 AM
TypeSH's Avatar
TypeSH
use a c-clamp or tool that looks like it designed for pushing back the caliper
Old Mar 9, 2003 | 12:20 PM
RandyP's Avatar
RandyP
I have tried that and it doesn't budge.
Would the position of the emergancy brake have any thing to do with it?
Old Mar 9, 2003 | 03:40 PM
RandyP's Avatar
RandyP
It seems that there is somewhat of an engineering problem at Honda.
http://www.crxsi.com/resources/forum...cgi?1031065656
Any suggestions?
Old Mar 9, 2003 | 11:53 PM
frank's Avatar
frank
frank from canada
when i redid my brakes i just manually squeezed them together with my fingers..? mine was a 93 honda civic though...
did you uncap the brake resevoir under the hood? or does that even matter?
Old Mar 10, 2003 | 11:42 AM
Hondaman's Avatar
Hondaman
Black Pearl
Usually the back brake caliper pistons must be rotated to turn them back in. They make a special tool to do it with. Otherwise, carefully use a channel locks to turn it back in.
Old Mar 10, 2003 | 01:30 PM
sunshine's Avatar
sunshine
Torqueless Wonder
the front calipers need to be pushed in with a c clap and the rears need to be rotated back in. I use needle nose pliers to rotate the piston back in.
Old Mar 16, 2003 | 01:06 PM
RandyP's Avatar
RandyP
Thanks, that was it.
