FWD Honda/Acura: DIY Tire Rotation
Old May 21, 2006 | 10:29 AM
vtec rider's Avatar
vtec rider
h22 under the hood
probably 80lbs ft of torque
Old May 29, 2006 | 07:46 PM
97lCivic's Avatar
97lCivic
for people without directional tread, a better way to rotate is to put the front left to the rear and same with the right side.
now, take the left rear and put it on the right front and the right rear on the left front.
(this way is for non-directional tires and gives you a better even and overall tread wear)
Old May 30, 2006 | 06:14 PM
sherwood's Avatar
sherwood
I missed Sean
in my experience this method require more effort than it is worth for minimal results, unless you have some crazy disorder that only allows you tot make left turns, then by all means do this, but honestly the big difference in wear is bewtten the front and the rear, not on the sides.
Old May 31, 2006 | 03:24 AM
Kai's Avatar
Kai
Rotorphile.
Originally Posted by Honura_Kit
what's wheel torque for RSX 05' ? Thanks
All 19mm lug nut Hondas, including the RSX, are 80lb-ft.
All 22mm lug nut Hondas (new Odyssey and Pilot) are 100lb-ft.
Old May 31, 2006 | 12:16 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
not a bad right up!
Old Jun 23, 2008 | 09:09 PM
jeldemire917's Avatar
jeldemire917
cross rotating tires to different sides is never a good idea, believe me, I work in a tire shop.
Old Jun 24, 2008 | 02:14 PM
Civic2Scooby's Avatar
Civic2Scooby
ok, stop bumping old threads, annnnnnd you are wrong.
Old Jun 25, 2008 | 03:12 PM
sherwood's Avatar
sherwood
I missed Sean
Actually it's a great idea... sans the fact that a lot of tires are directional and can't be swapped side to side anyway- in which case you're right. Otherwise you're painfully wrong.-- I personally just wouldn't use my time swapping them side to side.
Reading: http://www.tirerack.com/tires/tirete....jsp?techid=43
[/thread]
Old May 26, 2025 | 09:25 AM
daryelcorran's Avatar
daryelcorran
Why does it go from Tire rotation, to changing your spark plugs??
CivicSiRacer
92+ Civic/EL & Del Sol
Jun 22, 2003 07:10 PM
rlschi36
Do It Yourself
9
Mar 28, 2003 08:21 AM
reddemon009
Mar 20, 2003 03:13 PM
TMOTORS
Accord
Jan 8, 2003 07:27 AM
