Misc. Honda/Acura: Battery Replacement
Old Jan 17, 2003 | 05:04 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Default Misc. Honda/Acura: Battery Replacement
Import Street Scenes - News, photos, videos and info .. straight from the streets!
http://www.importstreetscenes.com
Thanks www.accordracing.com for the DIY
1) Purchase the new battery recommended and rated for your car (the parts dealer and your mechanic will have that information).
2) Be aware that the old battery is usually exchanged for the new one for recycling purposes, so you can either take it with you or drop it off later.
3) Open the hood of your car and locate the battery. Disconnect the cable terminals from the old battery's terminals (negative/black first and then positive/red).
4) Remove the frame or bracket holding the battery in place, and lift the battery out. Clean the cable terminals with a wire brush and baking soda and water if they're corroded or dirty. Use a wire brush or a battery terminal cleaner (a very inexpensive tool) to scrape the inside of each cable terminal to expose new, clean metal to the new battery terminal. If the cable terminals are damaged, they need to be replaced.
5) Lower the new battery into position, with the positive and negative poles in the same relative positions as before, and secure the frame.
6) Connect the cables to the new battery securely - positive to positive and then negative to negative. The cable ends should not be able to move at all; any looseness can prevent your car from starting. Test the battery by starting the engine.
7) Battery prices vary widely, so shop around. Buy a battery that has at least a 60-month warranty. Avoid cheap batteries - brands like Interstate and A/C Delco tend to last longer.
8)Make sure the battery is fully charged before you buy it.
9)Wear latex gloves to avoid dirt, grease and corrosion.
10)Some dealers will install a battery at no cost if you buy it from them.
Old Sep 18, 2007 | 12:24 PM
sebekhoteph's Avatar
sebekhoteph
I noticed that on the battery, the plate where the bolt is inserted, to hold the clamps together, is bent in a way to prevent the bolt head to move. Must have been done to prevent battery theft, but now, I find it impossible to unscrew the bolts, and thereby remove the terminal wires from the battery. Any suggestions how to do straighten the flanges to remove the terminal cables, without damaging the battery?
