Honda Accord 98-02: Pollen/Dust Filter
Old Jan 9, 2003 | 11:05 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Originally posted by wilsel
Anyone know if civics have a dust filter in them? Cause my gf's civic smells everytime you turn the heat on.
What year, bro?
Old Jan 13, 2003 | 08:17 AM
wilsel's Avatar
wilsel
Her's is a 2000, I have a 95. As far as I know mine doesn't.
Old Jan 13, 2003 | 11:02 AM
98CoupeV6's Avatar
98CoupeV6
I'm pretty sure hers does. Look in the owners manual or the original window sticker, it will say on there. "Micron Air Filtration System".
Old Jul 16, 2003 | 08:28 AM
NightRider79's Avatar
NightRider79
ight i have a 5th gen..
when i turn the ac on it smells funky for a sec. and spits a little dust out.
How can i get that damn dust to stop comin out?
Old Jul 17, 2003 | 01:40 AM
gradas's Avatar
gradas
I have the helm inc manual. It really helped to replace the micron filters. however I still have the gust of unpleasant smell when I start the car (with or without AC). the smell goes away after a couple seconds. anyone have any idea where this smell is coming from? I have a 99 accord EX couple.
Old Jul 20, 2003 | 06:39 PM
fastball's Avatar
fastball
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
That's the same procedure for 99-01 Preludes as well. I wonder if you use the same filters and Honda just has different part#s, since mine were 30.00 each and that was the cheapest I could find anywhere . That would suck if I could have bought the Accord filters for half the price and they're the same ones.
Old Jul 23, 2003 | 09:28 PM
kaliraver69's Avatar
kaliraver69
Good info Jschmid, bought the two filters will try to install this weekend.
Old Jul 26, 2003 | 10:52 PM
kaliraver69
I finally did it, pretty good tip on that Jschmid I never knew about that. I can diffently tell more air is coming into my car and it smells like clean air . Took about 45 min. to do.
Old Oct 28, 2003 | 02:07 PM
sleepyfloyd's Avatar
sleepyfloyd
I have a problem guys. I did everything above which was simple enough. But when I got to the step where I had to remove the lower bar, I kinda got stuck. The 2 screws holding the bar were on tight. So what happened was I ended up stipping the 2 screws. Now I can't get the two screws out to take off the filter cover. Is there anyone who can help me out before I take it to a mechanic and get charged for this.
I was looking online and found that craftsman sell a damaged screw driver set called screw-out. If anyone has heard of this, can you tell me if it works. Someone also said that if I heat it with a torch, it will loosen the screw. Is that true?
Old Oct 28, 2003 | 05:01 PM
chrisexv6's Avatar
chrisexv6
This is exactly what happend to me. But I figured out that if you fudge the lower bar a little, you can get the air filters to fit. My advice would be to try a Vise-Grips if you have one to clamp onto the screw head and get it (them) out. Then go to Home Depot and get a decent replacement screw with the same thread size (anyone know what it is?) but with a HEX head, instead of just a philips. Then reinstall the new screws.
I wish I had taken the time to do this on mine. Maybe in another 30K miles.
By the way - Pep Boys had no-name micron air filters for 11.00.......I thought it was 11.00 each and bought two, but it actually turned out to be 11.00 for two. Not even close to Honda price, and they looked exactly the same as stock.
-Chris
