DIY-Bolt Extraction
Old Aug 5, 2006 | 11:37 AM
kidd_honda's Avatar
kidd_honda
Default DIY-Bolt Extraction
Well my caliper bolt broke in half inside, so i decided to do
a DIY for people who might have the same problem in the
future.Sorry for the pic quality. Crappy camera.
The alternative:
http://honda-tech.com/zerothread?id=567450
Heres what you need:
-Goggles (Dont want to lose an eye)
-Gloves (unless you want heavy crud under your nails)
-Lubricant (Liquid Wrench or Wd-40)
-No.1 Screw Extractor
-T-Handle Tap Wrench
-Drill with 1/8" bit
-Hammer (not included in the pic).
Craftmans 1/4 - 1/2in. Steel Tap Wrench = $4.99
Craftsman No.1 Screw Extractor = $2.99
Craftsman Specification:
Screw Extractor----Drill Bit
No.1---------------No.30 (1/8")
No.2---------------No.12 (3/16")
No.3---------------15/64"
No.4---------------5/16"
No.5---------------3/8"
No.6---------------15/32"
No.7---------------9/16"
FYI: DO NOT GET THE SPIRAL EXTRACTORS. I HEARD THAT THEY
BREAK EASILY. GET THE NON-SPIRAL ONES.
1. First, spray some lubricant in the area. Let it soak for 2
mins. or more. Then, drill in the center of the bolt using a
1/8" bit. Spray more lubricant after you drilled the hole.
2. Second, put the screw extractor into the hole and tap it
in with a hammer.Get it deep enough to get a good grip on the
broken bolt. Then attached the T-Wrench like so.
3. Finally, turn it counterclockwise and Viola!!!
Bolt no longer OWNS me!!!!
BOLT IS OUT!!
THANKS FOR LOOKING
KIDD_HONDA
Old Dec 4, 2006 | 04:25 PM
cheeto985's Avatar
cheeto985
Nice, I have a couple of volts that are broken too. I'ma have to try that.
Old Dec 4, 2006 | 05:30 PM
lkailburn's Avatar
lkailburn
college kid
great job
Old Dec 5, 2006 | 08:15 PM
fathom22's Avatar
fathom22
Banned
nice!
Old Dec 6, 2006 | 05:17 AM
fjm1's Avatar
fjm1
G35
Good post, thanks
Old Dec 22, 2006 | 02:40 PM
rmfbmf's Avatar
rmfbmf
Your pics illustrate the process well.
A different option that a mechanic friend told me about is to skip the screw extractor altogether. Buy LEFT hand drill bits--I found a set of 5 at the local auto parts store. Use a punch so that your drill won't wander when you start to drill (good advice whether you use the screw extractor method or not). If you're using the left hand drill bit be sure to run the drill in reverse. Normally, once the drill gets in a little ways the screw remnant will simply back itself right out. 9 out of 10 times I've used them it works just as described. The other 1 out of 10 I have to follow up with the screw extractor.
The only sound worse than a bolt breaking off is breaking off a screw extractor trying to get one out. They are a necessary tool, but I prefer to avoid having to use them if possible.
Old Jan 3, 2007 | 03:30 PM
nanoeverything's Avatar
nanoeverything
Default Broken bolt
I don't understand why you have to do what you did. Were you working on a rear disk brake bolt on the caliper? I had recently a cross-thread bolt inside the pin on the caliper of a Honda Accord (6th generation) preventing the bolt from being tigtened or taking out. What I did was cutting bolt hax head off with a saw, and then pulled the pin out and discarded the pin with a stuck bolt inside. I bought a pin for $7 and a 8.8 metric bolt ($0.50) from Home Depot. I am not sure if I am speaking about the same thing as you did.
chimchim
Do It Yourself
57
Jun 16, 2025 09:52 AM
hoyoung02
92+ Civic/EL & Del Sol
11
Dec 18, 2006 08:25 AM
ReVenGe
Do It Yourself
4
Jul 4, 2006 05:01 PM
eonsx311
27
Jun 15, 2005 05:27 AM
