Home-made Short Shifter
Old Oct 27, 2005 | 10:04 AM
raiden571's Avatar
raiden571
turning u inside out
EASY CHIEF!!!! once is enough, lol
Old Oct 27, 2005 | 03:38 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sorry, just had to make my point loud and clear. h:
Double post times two. :chuckles:
Old Feb 12, 2007 | 09:36 PM
autotracer's Avatar
autotracer
Yea, OK BUDDY! ^_-
Default please DO NOT DO THIS MOD!!!
Anyone thinking about doing this mod - don't. It's really cheap (50$ on ebay) and freaking easy as crap (took me like an hour and I knew nothing of mechanics at the time) to install a B&M shifter in my old '95 civic. I just bought a '97 ex off a guy, and he had previously cut the shifter shaft about 3-4" down. This after constant usage messed up the internals in the gearbox and cost me a new transmission (it was grinding into 3rd and 4th gears after the 8-9 months after he did it). Maybe it was just the way the guy drove the car, or maybe it was a freak accident, who knows this is just my experience that i've learned from.
$50 > new transmission.
but that's just me and my noobieness.
Old Feb 23, 2007 | 09:59 AM
hondub's Avatar
hondub
^ -dub +da
I know im a little late but i just wanted to say that cutting your shifter isnt going to hurt the internals of the tranny. A real short shifter probaably does more damage due to faster movement of shafts which could be hard on the sychros. And to make a shifter, cut a little off the top then cut the little peice of the end where the shifter hooks to the linkage and weld the little piece you cut off the top in between the ball and the bearing housing. Or buy a $10 ebay one.
Old Mar 7, 2007 | 02:41 PM
88'CRX's Avatar
88'CRX
well hey the guy i bought my crx from did this to my shifter and it does feel shorter to me...and ya cutting it like this really would have no effect on the transmission in terms of hurting it...but are the shifters from ebay actually good? are they worth it cuz i heard they are kinda cheap and weak..
Old Mar 8, 2007 | 11:15 AM
katraloko's Avatar
katraloko
nice i should try it
Old Mar 8, 2007 | 01:04 PM
sherwood's Avatar
sherwood
I missed Sean
Originally Posted by Däs Schmoo
No, the difference is a longer fulcrum on the shift rod end. There was nothing done to shorten the throw of the knob, so it was pretty much worthless. I actually measured the length of the Skunk2 vs my stock one and they are the same length, just the pivot point is higher up the shifter.
Whatever floats your boat....:dunno:
i thought i was the only one capable of this :chuckles:
Old Jul 14, 2007 | 01:39 PM
90_crx_flaze's Avatar
90_crx_flaze
Drift King
heres my therory on short shifters, most of the aluminum ones ive drivin with i snapped i dont think i shift hard but yeah i snap then bitches, i have a stock shifter i cut down about 2 inches, and found a old half inch pipe layin around cut it about half an inch long used a hacksaw and cut the shifter under the ball about half way between and welded in the peice of pipe and its been holdin good for about 4 years now, i did retap the shifter and put an oem knob back on and the gears are short and quick. anyone ever heard of a robo shifter? mounts on top of the linkage instead of underneath and its over a foot long and fully adjustable
Old Aug 8, 2007 | 12:41 PM
Accordman95's Avatar
Accordman95
17 inch polished 6s
does anyone know if the P-spec shifters are any good? Cause I'm bout to buy one.
Old Aug 8, 2007 | 01:32 PM
sherwood's Avatar
sherwood
I missed Sean
are you positive you need/want a short shifter.... seems like an awful waste to me.
