short shifter
Old Sep 15, 2005 | 04:26 PM
chod's Avatar
chod
Default short shifter
how do you chnage ur oem shifter to a short shifter? is it hard?
Old Sep 15, 2005 | 07:33 PM
Hatchbak89's Avatar
Hatchbak89
"hey flip that cow pie!"
Not to be an ass, but read the stickies, this is a forum for DIY instructions not "how do you do this?" I did it too, just letting you know.
Old Sep 16, 2005 | 05:10 AM
mrbkkt1's Avatar
mrbkkt1
Aiea, HI
you will need to go under your car and through the cabin. having a lift will make it super easy but at least jackstands will make it tolerable. i did my civic before in about an hour(not counting breaks)
Old Sep 16, 2005 | 06:27 PM
97civicEXVTEC's Avatar
97civicEXVTEC
its not that hard its just a pain in the ass to get under the car if you dont have a lift and manuver
Old Sep 17, 2005 | 01:36 AM
hurleyguy145's Avatar
hurleyguy145
d16y8 bolted uP^
So how exactly did you "Do It Yourself".......
wned: wned: wned: wned: wned: wned: wned:
D-SERIES POWN JU! BOW TO THY Sock Vtech :deek:
Old Sep 17, 2005 | 02:18 AM
mrbkkt1's Avatar
mrbkkt1
Aiea, HI
it's a relatively easy bolt in affair. as long as you have ample access under your car. on a scale of 1-10, i'd give it a 4., a 2 if you have a lift. i think you could even use ramps!
Old Sep 29, 2005 | 08:29 PM
C2daIzZle's Avatar
C2daIzZle
super easy, get some ramps.
Old Sep 30, 2005 | 06:05 AM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
you can..
cut the OEM shifter down and get a tap and die set and get new threads in.
OR
you can go on eBay and order some cheap short shifters.
take your shift knob and boot off.
jack your car up, and unbolt your oem shifter.
and replace the shifter only, refit the bushings and bolts back on, and put everything back together.
Old Oct 22, 2005 | 07:55 PM
accord2016's Avatar
accord2016
Accord European Model????
are there someone to accord ES???
Old Apr 2, 2008 | 08:15 PM
Stewiie's Avatar
Stewiie
its pretty easy took me 20 mins
