I did a stupid thing, now I need help!
Old Sep 10, 2005 | 07:10 PM
VPUPPY's Avatar
VPUPPY
there is a main FUSE, it should be in the under hood fuse box. its a bigger fuse than the others. the main RELAY has to do you with your fuse injection and fule pump.
Old Sep 10, 2005 | 10:52 PM
sleepee's Avatar
sleepee
WestcoastImports.net
beeek is right i did the same thing once because the shit was labeled i was in a rush and didn't route the cables to the starter and ground and blew the BATTERY FUSE.
check that...then the Main Relay.
Good luck
Old Sep 11, 2005 | 09:55 AM
delsol161's Avatar
delsol161
Originally Posted by beeek9
just change the battery fuse, thats it. if u wanna know before buyin the fuse. just put 2 wire on both side of the fuse and try startin the engine
Good luck
makes sense, check that for sure.
